Components
05/10/2024 at 21:19 • 0 commentsIC 2 M27C1001 labelled AR8000-00135-008-104
This is an 128K x 8-bit EPROM.
The data appears very sparse, to say the least.
00000 to 01fff: all FF 02000 66 23 80 3f 66 3c 41 3f 02008 to 1ffff: all zero
which disassembles to this
0: 66 23 80 3f 66 3c 41 and ax,WORD PTR [eax+0x413c663f] 7: 3f aas
which does not look like useful code.
I think it is two little-endian 32-bit vectors:
3f802366 3f413c66
Underneath the board are two Intel E28F008S5 surface-mounted flash ROM chips. That is 2 Mbytes total enough to store the ROM-based DOS. I will have to read them when I have the board up and running.
