nunchuk2sac
nunchuk2sac reads a Wii nunchuk joystick and buttons then drives three Sony Access Controller expansion ports using a four channel DAC.
0 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
The Sony Access Controller (SAC) for PlayStation 5 (PS5) includes 10 buttons, a joystick, and four expansion ports. The expansion ports are for analog joysticks, analog triggers, and buttons.
The Wii Nunchuk handheld controller has two buttons and a joystick.
This project reads the nunchuk joystick and button inputs then drives three SAC expansion ports to relay the button presses and stick movement. A four channel DAC has just enough outputs for this.
Arduino and CircuitPython code are at https://github.com/esp32beans/nunchuk2sac
