LTE Business card
The idea is - a business card which is pre-programmed and will call to the business owner and you can talk from business card itself.
A business card which will call to the owner like phone and you can talk with owner as it has GSM, mic, speaker and programmable button. form factor is 90mmx50mmx~5mm.
Main controller is ATtiny85-20s which is connected with serial port to LTE IC - quectel ec200u. Owner's number can be hardcoded in attiny's flash to call the owner. there is 1 push button connector to attiny which can be programmed as you want. Mic -4013SMTis placed on pcb and for speaker 8ohm 0.5W will be soldered on pcb with wires. Sim connector is 6 pin. this is my first project on hackaday.io and have not tested it physically but i have worked with components in another projects so it is possible in theory. i hope you like it and give suggestions to improve it. in future we will try to make it physically.
Busi_card_v1.kicad_pcb
kicad_pcb - 591.45 kB - 05/16/2024 at 07:07
Download
Busi_card_v1.kicad_sch
kicad_sch - 246.50 kB - 05/16/2024 at 07:07
Download
Busi_card_v1.csv
Comma-Separated Values - 1.49 kB - 05/16/2024 at 07:06
Download
  • 1 × ec200u -quectel lte IC LTE module
  • 1 × attiny85-20s Microprocessors, Microcontrollers, DSPs / ARM, RISC-Based Microcontrollers
  • 2 × SP0502BAJT esd 2ch
  • 9 × capacitor 33pf - 0201SMD
  • 1 × capacitor tantalum 100uf 16V EIA-7343-15
View all 21 components
  • costing estimation
    Sandeep Singh05/16/2024 at 07:34 0 comments
    costing estimate:
    In India if order individual components  - around 18-20$ usd
    for one pcb maximum - $5
    I have not build it physically yet.
View project log
janussanders wrote 07/03/2024 at 18:33 point
Sandeep,  I'm in.  I was wondering if you have some code for the ATtiny?  I created a project for the ATtiny85 using arduino to make a game and project it to an LCD.  Could be helpful.
Sandeep Singh wrote 07/08/2024 at 17:17 point
Hi, janussanders, i haven't written code for attiny, however I have done a test with esp32 on arduino core with AT commands to communicate with gsm. We can discuss your project, I'll help you if i can.
Alana B wrote 06/05/2024 at 17:44 point
This is an amazing idea.
Sandeep Singh wrote 06/06/2024 at 04:30 point
Thankyou, I will definitely make it physically with improved version of it.
