This project was largely inspired by the NB10000 from Nitecore!
The power bank is based on the IP5355 from Injonic (datasheet is in chinese, use google translate) and utilizes a 9858102 3.85v 10000mAh Lithium polymer cell. The enclosure comprises of a 60mm x 12mm carbon fiber tube + PC-ABS 3D printed fittings on each end. Its weighs ~168.5g and is approximately 129.2mm x 60.0mm x 11.9mm.
To maximize water resistance, IP rated components were used as much as possible (e.g Alpine SKTDLDE010 IP67 Switch and TE 2305018-2 IPX8 USB-C Connector). The fittings at both ends are designed to have a good fit and can be hermetically sealed with adhesive/epoxy. Additional waterproofing can be achieved by applying a conformal coating to the PCB.
Both USB-C ports support up to 18W input/22.5W output fast charging via USB PD3.0 (Fixed: 12V@1.67A, 9V@2.22A, 5V@2.4A and PPS: 3.3V-11.0V@2.00A) and other protocols* (QC2.0/QC3.0/QC3+/QC4+**, BC1.2, Apple 5V@2.4A, AFC, SCP, FCP)
All design (Schematics, PCBs, 3D Models) and production files (Gerbers, BOM, PicknPlace) are available under the CC BY-SA 4.0 license
Disclaimer: Lithium batteries are inherently dangerous. Improper handling may result in fire, explosion, damage to property, injuries or death. Please take the necessary care and precautions when handling lithium batteries. All materials in this repository are experimental in nature and are provided AS IS, without any warranty, explicit or implied, including but not limited to warranties of merchantability, safety or fitness for a particular purpose. By using materials contained in this repository, you agree that you do so AT YOUR OWN RISK.
AxxAxx
Vitaly Domnikov
electronicsworkshops
Stefan Wagner
