The Peugeot Scoot'elec is an early BEV moped that was powered by an 18 volt NiCd pack made of 3 x 6v (100 AH) mono bloc flooded cells (made by Saft) and a brushed traction motor. My example had obviously been dropped and is not in perfect condition. The original motor controller was a Peugeot designed unit, as such, special diagnostic equipment was needed to 'service' the bike. Because the NiCd batteries need periodic topping up with deionised water, the motor ECU came with a built in safety feature, in that it would limit the speed when a water top up was over due.
The only way of clearing this mode of operation was to plug in the special Peugeot diagnostic tool, which I don't have. So, I bought a Curtis Sepex 24v 150A motor controller which can be programmed to suit my motor / application. The Curtis programmer is expensive, but it is available.
Two friends are helping me with the restoration, I'm working on the electrics and they are helping with the bodywork and fabrication.
Mark Kelsall
Ampeater
Rory
Peter Buckley
mircemk
