Or: How small can makers make things
iGA.2 - schematic XG7F.pdfSchematic as .pdfunknown - 140.28 kB - 01/27/2017 at 08:22 |
iGA.2 XG7F.dchDiptrace 3.0 Schematicdch - 510.52 kB - 01/27/2017 at 08:22 |
iGA.3 XG7F.dipDiptrace 3.0 PCBdip - 385.19 kB - 01/27/2017 at 08:22 |
iGA.3 XG7F_asy.dipDiptrace 3.0 PCB incl. case partsdip - 532.73 kB - 01/27/2017 at 08:22 |
iGA.5 - BOM.csvBill of Materials, PCB mounted parts only, full list of materials on instructables.comComma-Separated Values - 1.29 kB - 01/27/2017 at 08:22 |
The PCB assembly worked even better then expected, it definitely will be my go to option for small builds like this :)
@Hari Wiguna - this is what I had in mind, when you we're doing your tiny RGB cube and I was saying stuff like "planning even smaller". My concept was only an idea and I don't think I would have ever done it, now definitely not :)
This is great :)
I totally agree! nqtronix did a fantastic job. If you haven't already, check out his instructable. There's a ton more detail there.
Crazy impressive soldering, well done! I love the PCB structure!
