1Step 1
Software Requirements (as used/tested by author):
- Latest Raspbian OS - Python 2.7 - Kivy (Ver 1.9.2 dev) UI framework - Additional required python packages: - w1thermsensor - FakeGPIO (for testing on non-Pi platforms, customized version included) - CherryPy (web server) - schedule (for scheduled events) - bluepy - subprocess32 - openweathermap.org app key
Software installation:
1. Make sure you have the latest Raspbian updates 2. Install Kivy on your Pi using the instructions found here: http://www.kivy.org/docs/installation/installation-rpi.html 3. Install additional python packages: CherryPy, schedule,bluepy,subprocess32 & w1thermsensor using the command "sudo pip install ..." 4. Get an openweathermap.org app key if you don't have one from here: http://www.openweathermap.org/appid 5. Edit the thermostat_settings.json file and insert your Open Weather Map app key in the appropriate spot. Also change the location to your location.
