ESC.VTOR
Ground station deck to control (some of) them
A bulky, yet portable, RPi4 based cyberdeck with sticks, CVBS signal chain and control tranciever.
Pronounced "escape vector".
The unit offers what you might need on a ROV control related mission, including, but not limited to:
- basic set of controls that suit drone operations - a pair of sticks, trims, a set of switches and buttons and all governed by a (unofficial) port of Edge-TX;
- transmitter bay that can carry any micro JR TX module - but since ETX port only supports CRSF connection - that restricts the selection to ELRS module types;
- two displays, one of which can be detached, used separately and has analog video input; said detachable display also can be extended via module ports;
- Raspberry Pi 4 to launch mission related stuff;
- analog video chain with 3 inputs, 3 outputs and local OSD generation/injection; rail mounted caddy allows to install a video receiver to use as one of the inputs;
- an RGBA torch for darker missions;
- a macropad-like input panel that by default comes with d-pad, F1-F4, PgUp/PgDown/Home/End, mouse left/mouse right/mouse middle buttons configured - but can be reassigned to anything else; also comes with mouse pointer joystick;
- if macropad isn't enough, there are two USB inputs - one on the front panel that leads to internal hub, and one on the back panel that connects directly to SBC; additionally there's ethernet connector;
- in case it must be lifted (3kg of it's mass is no fun to hold with your two), there's a tripod attachment frame;
- and much more! (goggles mount/strapping panel, external rail mounted 2S 26650 li-ion battery pack, cool missile switch + VA meter + 10A external fuse block, handles, sling mounts, internal UVC device, servo control input/output, selectable USB host for ETX - internal for mission software or external for simulator connection ...)
What is still WIP:
- ETX port is not complete since it is based on still in development v3.x version that was not released; the rest of RC part can feel spartan, but it does have PPM trainer output and basic sound alerts working; auxiliary potentiometer is not connected to ETX since it requires additional ADC input to be routed;
- mission software/MAVLink connectivity were not tested;
- wider voltage range for transmitter bay;
- local OSD only supports timer/stopwatch display;
- input module (ACU) needs better joystick handling and different modes for it;
- neither display has touch support;
- inputs (USB/video/power) are barely protected from shorts or static;
- decal job needs more precision and overall case needs tolerances to be worked out;
- and much much more! :D
  • 2 × 0.96" I2C White OLED display ORIGINAL BIGGER SIZE VERSION For input processor and radio controller
  • 1 × WeAct STM32H562RGT6 minimal system board For radio controller
  • 1 × 1206 1A PolySwitch Self-recoverable fuse for radio controller's power
  • 1 × Low ESR 25V 4.7uF 25TQC4R7T 3528 Type B SMD Polymer Tantalum Capacitor Radio controller's power
  • 1 × RP2040 Pico Zero No headers, with USB type-c soldered on - for input processor
View all 29 components
  • Surpass
    mkdxdx3 hours ago 0 comments
    Now featured at Cyberdeck Cafe!
    https://cyberdeck.cafe/mix/esc-vtor
  • Saturate
    mkdxdx04/05/2026 at 22:48 0 comments
    Teaser before everything that is hidden under the break:
    It is time to spice up the sterile attire.
  • Scream
    mkdxdx01/29/2026 at 03:10 0 comments
    Fine folks at EdgeTX project are spearheading the H5 port base so consistently, I was able to enable DAC driven sound on my port almost fuss-free.
    Uses external amp though - but that should be fixed in the next board revision, among othet things.
    The project is alive, but power grid situation doesn't allow me to make steady progress - the infrastructure is constantly being damaged, temperatures fall and it's not fun.
  • Sway
    mkdxdx10/12/2025 at 19:35 0 comments
    It's not an FPV themed deck without something FPV proper, right?
  • Surge
    mkdxdx10/01/2025 at 13:11 0 comments
    A lot happened!
  • Spin
    mkdxdx07/08/2025 at 22:05 0 comments
    EdgeTX port is mostly done.
    It has everything I need to more or less evaluate how well the project fares in RC department.
    Still some features are missing like voice or working trainer port, but I can control a drone with what's available.
  • Source
    mkdxdx05/19/2025 at 22:31 0 comments
    A bit of an update to keep the log alive, because next ping won't come soon.
    With input processor done, project now moves to it's right side - the TX part.
    And there are at least two ways to go about it.
  • Strafe
    mkdxdx04/27/2025 at 00:52 0 comments
    It's been a while.
    The input processor firmware has been more or less shaped up, some things still need work, but at least I do not have to keep this board on my table for now.
  • Stitch
    mkdxdx02/22/2025 at 00:14 0 comments
    It's a bit disappointing when it took a lot of time to do things but these things sort of can't be shown clearly because they are not visually significant and quite messy.
    More after the break.
  • Sophisticate
    mkdxdx12/24/2024 at 02:34 0 comments
    Some eRr Gee Bee action to make things fresh. Everything else below the break.
View all 24 project logs
benkster wrote 08/15/2025 at 12:33 point
Very nice project ! Definitely inspiring me
Burnt wrote 11/19/2024 at 04:32 point
Dude this is so fucking cool!  Love what you've done, and will follow closely
