There are people who tried to reload things like if they are scifi weapons (Kommander Karl style) and those who aren't entirely honest about it.
A lot of things happened since the last log - some progress and a detour in the middle.
So I was gaining some momentum in this project and then Cyberdeck Cafe has bitten me with this idea to share with people how I go about designing things in FreeCAD - throwing me out of the saddle for two weeks.
It has ended so bad, I came up with an actual haphazard writeup of how to model your own portable terminal in FreeCAD from concept, to a production-ready handheld, including my own, 14th in a row explanation of what it the most problematic thing in FreeCAD and how to trick around it.
If you ever wanted to either push through a wall of semitechnical text or just curious how to make things in this software, here is an attention attracting picture of the result:
And link to tutorial: https://bitbucket.org/mkdxdx/howtobuildashelf/
Other updates: rail-mounted battery pack, VRX mount, primary circuit breaker, new monitor and ELRS micro TX caddy - as usual, below the break.
So, a replacement monitor has arrived instead of the one I've almost wasted previously. This one has different scaler board so some fixes had to be applied, and good thing is - it has same button board as the bottom monitor, so now front panel looks a bit slicker:
Circuit breaker
The deck now has primary power ingress module that accepts XT60, runs power through ASW-07D "helicopter" toggle switch, optionally (it is also modular in itself) continues running it via a 10A automotive fuse and volt-amperemeter module and then gives you another XT60 to plug it into the deck's main power input.
VRX caddy
Next is the VRX holder/caddy/carrier thing, which also suffered some iterations before settling on something digestable.
ELRS TX micro JR bay carrier
Honestly I have no idea what's the correct name for this module format because it has like 2 or 3 different names, but I can now mount the thing into one of the bottom panels and have it's antenna sticking out when in operation. It also allows the module to breathe and all - but eventually it will be moved under VRX to allow for left stick to be moved even further to the left.
I've learned a lesson from previous build that having internal batteries does not allow you to do much so it is now external and mounted on aluminum frame in the back. It was iterated at least twice too, first being balls to the wall DIY (because even contacts were made of some tin cutouts) and second one finally featuring some readily available springy battery contacts plus some levers for cool reload animations, like it was shown above to grab your attention. Balance leads included.
mkdxdx
