PCB Design
A project log for SOS Business Card
Business card that generates Morse code SOS signal using discrete logic components.
martynasMartynas 05/31/2024 at 20:500 Comments
PCB designed using KiCAD. I tried to use SMD as much as possible, for ICs - SOIC package and for discrete components - 0805 size package.
Check schematics.pdf for full circuit schematics. There are some custom symbols and footprints used in this project. Those can be imported from this github repository.
PCB is dual sided with most of the traces on top layer. Bottom layer dedicated for business card stuff - name, barcode which points to my github and artwork.
I ordered PCB on JLCPCB with black soldermask and board thickness of 1.2 mm.
