Power and Output
A project log for SOS Business Card
Business card that generates Morse code SOS signal using discrete logic components.
martynasMartynas 05/31/2024 at 20:340 Comments
Circuit will have 2 power options:
USB-C socket CC lines are connected to ground via 5.1K ohm resistor. This tells power source to supply 5V on VBUS line. Most ICs I chose have maximum supply voltage of 6V.
The circuit will have a small on-board LED for SOS signal output. Additionally, a high-side PMOS load switch can be connected to a larger load, such as a 12V lamp. An external power supply with a maximum of 40V will be needed for this.
