Initial update
05/27/2024 at 16:26 • 0 commentsAfter creating a prototype on a raspberry pi Zero W for my own use, I realised that I should redesign it with a more production oriented mentality.
The current status is:
- Component selection completed (based around ESP32)
- PCB designed and tested
- Case designed, redesigned, and then redesigned again.
- Software under development
- using ESP-ADF and IDF
- need to finalise the menu and create some missing menus
- need to fix some bugs on the audio pipeline
- need to add OTA upgrades, and test robustness
Alexis D.
