Not all IOs are the same
A project log for eZ80 CPU for RC2014 and other backplanes
An eZ80 CPU Module that works within the RC2014 ecosystem and other similar backplanes
dean-nethertonDean Netherton 05/31/2024 at 02:350 Comments
Unlike memory, IO will be a bit more tricky.
If I were to run any existing Z80 software on the eZ80, I need to first configure the EZ80 to switch to its Z80 compatible mode.  As described in the previous journal entry, this mode allows the original Z80 instructions to execute within a 16 bit address range, where the top 8 bit address value is held in the special register MBASE.  So for the most part, code will operate as intended.
But this is not as simple for IO instructions.  In the eZ80 the IO instructions will apply a 16bit value to the address bus,  allowing for a full 64K addressing range for IO.  (The eZ80 does not use the full 24bit for IO access).
Technically the Z80 also addresses its IO using a 16 bit address.  But most designs just ignored the upper 8 bits of the address.  For RC2014™ and like systems, modules are typically designed to consider only the lower 8 bit of the address, giving us a maximum of 256 IO port addresses.  Software written will expect this to be the case, and so does not 'worry' about what value it places in the upper 8 bits.
This mean, existing software might address port 0x45 with a 'random' or undefined value for the upper 8 bits.  For example: it might address it as 0x1245 and then later on address it as 0xE445.  As the hardware ignores the upper byte, it all just works as expected.
Does this not means that the eZ80 and Z80 address IO in the same way?
Yes, but there is a problem that will need to be considered.  The eZ80 has many on-chip systems, UARTS, timers, and other system.  These all have associated IO ports to control them.  Zilog has assigned them within its reserved address range of 0x0080 to 0x00FF.
That means if any existing software designed for the original Z80, makes an attempt to write to some port, say at address 0x9F, it will place a random/undefined value on the upper 8 bits of the address. If this happens to be 0x00, then it will not access the device it intends, but rather the internal system port.
Any attempt to run existing code designed for the Z80 in the eZ80 in compatibility mode, may still need be modified to avoid port conflict issues.
The other issue is the timing/wait states applied to IO access.  If no wait states are applied, then the IO access will be way to fast.  To enable some wait states, I need to configure a chip-select line, (similar to how memory is done).  (This could perhaps be done off chip, but requires more external chips - I'd rather try and use the inbuilt features of the eZ80.)
Similar to how CS3 will be wired to the backplane's MREQ signal, I intend to wire the CS2 signal to the backplane's IOREQ line.  The appropriate wait states and address mode (Z80) can then be configured.
CS2 will be configured to activate, whenever the CPU is instructed to address IO ports in the range of 0xFF00 to 0xFFFF.  This will mean than existing software that address IO ports, will need to be modified to ensure it sets the upper 8 bit to 0xFF.
