Finished First Version of this design, Tests will be completed soon
A project log for Strain Wave Gear Robotic Arm
Mostly 3D Printed Strain Wave Gear Robotic Arm
jared-fensterJared Fenster 07/11/2024 at 06:560 Comments
The empty space within the FlexSpline is where the magnetic encoder will be placed for final joint angles. This design is still a little larger than I hope the final design is. I may look into optimizing some of the space where the motor connects to the planetary gear, possible make I direct connection to the input of the gear rather than the yellow piece that is currently between the two.
