The empty space within the FlexSpline is where the magnetic encoder will be placed for final joint angles. This design is still a little larger than I hope the final design is. I may look into optimizing some of the space where the motor connects to the planetary gear, possible make I direct connection to the input of the gear rather than the yellow piece that is currently between the two.
![](https://cdn.hackaday.io/images/5640951720680937940.png)
