Strength Test
A project log for Strain Wave Gear Robotic Arm
Mostly 3D Printed Strain Wave Gear Robotic Arm
jared-fensterJared Fenster 07/14/2024 at 22:080 Comments
I have tested the Joint in 1kg increments. The max torque it was able to achieve was 18 Nm, any greater mass tested causes the ABS FlexSpline teeth to skip. Still testing to find out how I can move forward.
Finally I found that the Joint sounds terrible, it might need some grease.
