The reason the teeth are skipping under load is the Circular Spline is flexing enough to let the FlexSpline teeth pass through. I will be adding metal components into the Circular Spline to fix this.
A project log for Strain Wave Gear Robotic Arm
Mostly 3D Printed Strain Wave Gear Robotic Arm
