I have tested the Joint in 1kg increments. The max torque it was able to achieve was 18 Nm, any greater mass tested causes the ABS FlexSpline teeth to skip. Still testing to find out how I can move forward.
Finally I found that the Joint sounds terrible, it might need some grease.
