Stronger Circular Spline
A project log for Strain Wave Gear Robotic Arm
Mostly 3D Printed Strain Wave Gear Robotic Arm
jared-fensterJared Fenster 07/15/2024 at 20:440 Comments
It seems with the stiffer Circular Spline, the strength does not change, rather if its not the teeth that skip, the motor just stalls. I am currently working on a fix. I may upgrade some parts to metal to prevent flexing in the Circular Spline as it is still present.
