I pulled the trigger and ordered PCBs and parts - so far everything except the displays. I've made a number of PCBs in the past ~15 years since I got into the electronics. Frequently I have made some silly mistake that has necessitated my ordering a new variation of a board. Of course every time I do it I try to be extra meticulous so as to not repeat the problem. As an abundance of caution, I ordered just 10 PCBs.
aren't visible looking at the board head-on
I decided to implement a button (again, inspired by Tom Nardi's Cyberdeck SAO) for stand-alone interaction. Initially I was going to try to do this as a capacitive touch pad, but I've had mixed success with those in the past and space was already tight. This button is connected to the GPIO2 pin on the header so it could be triggered from whatever its attached to. The SAO header also implements a pair of i2C pins. I like the idea of there being an API to draw on the screen, but that necessitates writing an i2C software stack to handle the second i2c.
Now I just have to wait for all the parts to get here. I'm not in a rush, and it's still a few months until SuperCon, so its going to be a couple of weeks. After I've successfully assembled a board, I can order the remainder of PCBs and all the displays.
Did you find a good source for the side-mount button? That ended up being one of the most expensive parts of the Cyberdeck SAO, think I paid like 50 cents a pop from Digikey.
I ended up going with the Panasonic EVQ-P7J01P. Because I had to get the Microcontroller from China anyway, I bought everything from LCSC. The price difference between LCSC and Digikey for this is almost half. I can only guess as to why.
I actually ended up paying more for the microcontrollers, buying through LCSC instead of the WCH store on Aliexpress. The latter offered an introductory deal of something ridiculous. It was just easier to have it all in one pack.
