1Circuit Diagram
I have included the circuit diagram above for you to follow. Next, Let us look at the explanation.
2Pin Configuration and Circuit Explanation
In this circuit, the pin configuration is as follows:
- Pin 16: VCC
- Pin 8: Ground
- Pin 5, 3, 14, 12: First 4 bits (P), where Pin 5 is the MSB and Pin 12 is the LSB.
- Pin 6, 2, 15, 11: Second 4 bits (Q), where Pin 6 is the MSB and Pin 11 is the LSB.
- Pin 4, 1, 13, 10: SUM output, where Pin 4 is the MSB and Pin 10 is the LSB (when there is no carry-out).
- Pin 9: Carry-out.
3Resistor and LED Setup
4.7k resistors are connected to all input pins to ensure a logic 0 state when the DIP switch is in the OFF position. This setup allows easy switching between logic 1 (binary bit 1) and logic 0 (binary bit 0). The circuit is powered by a 5V supply.
When the DIP switches are turned ON, the input pins are shorted with 5V. Red LEDs are used to indicate the SUM bits, and a green LED represents the carry-out bit.
This configuration allows for clear and straightforward monitoring of the binary addition process, with visual indications of both the SUM and carry-out results.
4After Assembling
Above you can see the assembled image of the circuit in the bread board. It might look messy, sorry for that!
