v0.4 PCB Design Progress
A project log for PICO9918
A replacement for the classic TMS9918A VDP, powered by a Raspberry Pi Pico (RP2040)
troy-schrapelTroy Schrapel • 06/26/2024 at 13:46•0 Comments
Started working on the next revision of the board (v0.4). The all-in-one.
Looking pretty good. Managed to have it mostly single-sided (good for cheaper PCBA). Most of the components will be on the underside. 4 layers with the middle layers being a solid ground pour and a (mostly) power layer. Signals mostly on the IC layer (bottom) with some on the back (top).
On the top side are a couple of optional LEDs for read and write (for those who like the blinkenlights). The Boot button and USB-C connector required for reprogramming to little RP2040.
Not ordering these yet as I like to give it a few days to "simmer" in case I think of anything I've missed or could do better. Likely order the initial batch next week.
