Ever since I entered the machining trade, I made it a fact for myself that I would eventually build up my own machine workshop, including CNC machines. I had been in the market for a CNC mill to start out with for some time up until now.
Given that this is my debut into CNC machining, it made sense to start off with something sensible, easy to run, and that can fit in my current workspace (i.e not a €60k Mori Seiki). I anticipated that my first mill could be a project rather than a turnkey machine tool, however this didn't bother me since I started off with 3D printing in a similar way, and it has been excellent for learning the subject inside & out.
An opportunity came in November 2023, with the machine in question being a used BF20 clone. The machine was already converted to CNC, albeit that, after closer inspection, it was evident that corners were cut, resulting in damage. I still, however, decided to take this challenge head-on.
Context: the below happened between November and December 2023.
After purchasing and successfully transporting the machine back to base, I was ready to give the machine a much needed teardown in order to take a closer look at everything. I started by dismantling the Z axis column from the base held by four long M12 bolts. The column was taken off as a complete Z axis assembly, and will be disassembled afterwards.
The X and Y axis were next, but to do this it became clear that the Y ballnut needed to be accessed from underneath. The base casting assembly was therefore unbolted from the base structure and flipped on its side. The underside exposed the Y axis ballscrew and ballnut (wrapped in aluminium tape for some reason), and a some amount of aluminium swarf stuck on the greasy bits of the machine.
After learning how the ballnuts are clamped to the saddle, the X axis, consisting of the table and ballscrew, was stripped off the machine. This of course revealed the root cause of the cracked casting, which was a cavity created with an angle grinder in order to make clearance for the X ballnut. Unfortunately, not enough care was taken and the casting became too thin near the middle, also penetrating through the casting in some areas. This therefore created a major weakpoint and became a perfect area for a crack to form upon application of stress caused by machining forces.
With that out of the way, the saddle needed to be taken out, but it seemed that there was no way of doing this without completely removing the ballnut from the ballscrew shaft. Ballscrews differ from conventional leadscrews as they contain many small, closely packed ball bearings inside to reduce the backlash as much as possible, among other advantages. Removing the ballnut without an appropriate tool meant that the ball bearings would fall out and the ballnut will need re-packing or replacement. Seeing how the ballscrew shaft was actually corroded in some areas, I decided to take off the ballnut anyway and the ballscrew assembly will be bought new completely later on.
Upon removal of the saddle, the crack was found to pass through the Y axis slideways. It was later discovered that the Y axis gib was also given the angle grinder treatment for some strange reason. This is unfortunate since machining new gibs will be a challenge, as it requires matching with the already existing tapered slideways.
With reference to the project description, I bought this mill used with a CNC conversion already done to it. It came complete with the stand, electronics and the OEM parts that were removed to make way for the CNC conversion, like leadscrews.
At first glance, the mill doesn't seem all that bad. When compared to other BF20 conversions out there, this example has much of the original parts, such as the quill DRO and spindle unit, remaining intact. The first signs of neglect are to be expected on any "project" machine tool, such as loose limit switches and random bolts missing.
What wasn't expected however, was apparent damage on various elements of the machine, as a result of the CNC conversion. These were mainly:
Damaged flange on Y axis stepper motor
Loose & damaged end support plate for X axis ballnut
And, worst of all, cracked saddle casting
Before jumping to conclusions, the machine was powered on and tested as-is. The mill has two separate systems; the spindle drive, and the axis drive systems. The spindle system is powered by a 700W motor through a gearbox with high or low speed ranges. It drives a tool with a #2 Morse taper, held on with a drawbar. The spindle turned on without hesitation, and all spindle speeds were tested, from zero up till around 2000RPM. It seemed to run quite well, and the spindle didn't show excessive heat after 30 minutes of spinning. It was noted that the tachometer periodically turned off, however this was seen as a very minor issue given that it did not seem to affect the rest of the spindle drive system.
The linear axes are actuated via three stepper motors of the same specification, through an Oldham coupling then to the ballscrew of the respective axis. Motion control is done through a USB SmoothStepper board, running off a PC via Mach3. After figuring out the installation of this software on a laptop, and establishing contact with the SmoothStepper board, the pinouts from the breakout board were noted and inputted into the Mach3 configuration. Together with the stepper drivers powered on, the linear axes could then be moved via the Mach3 interface.
Upon moving the X and Y axes however, all sorts of unfavourable sounds were produced. The X axis made a distinct "rattle" from the loose ballscrew end support, and the X axis ballscrew also had runout as a result of this. The Y axis audibly gave the impression of stick-slip, a possible result of tight gibs, lack of lubrication, and the cracked saddle. Thankfully, the Z axis seemed to run a fair bit smoother. The only shortcoming was a slipping Oldham coupler upon moving the Z axis upwards, which was resolved by simply tightening the clamping screw a tad more.
To some people, this machine would be classified as "too far gone" due to the amount of work it involves to bring the machine back to an operating state. I however, saw this as the perfect opportunity to debut into CNC machining, and I don't think there's a better way to do it than rebuilding your own machine completely BEFORE making the first chips (some previous machining experience is 100% necessary, however). On these grounds, the machine was purchased with the intent of performing a complete overhaul and optimization modifications to improve the machine's performance.
The process of moving the machine to my place then commenced. Parts like the spindle head and stepper motors were dismantled to aid in transportation, and with the help of a mate of mine, the machine was transported back to base. Following this, the machine will be dismantled completely and everything is to be closely inspected.
