Concept of a business card that can show if stray static voltage is present. Trying to bring down unknown polarity voltage to 5V.
thumbnail.jpgPic of the ESD testing that took place.JPEG Image - 548.10 kB - 11/18/2024 at 20:34 |
Fully tested out the designs including the neon bulb variation. The entire process is documented in this YouTube Video.
Just received the boards and parts! Now all I need is time to assemble...
6-12-2024 - initial board release. Will send out for build and test out design.
I included the schematic in with the images. It was the 2nd entry. If you wish to see how to build this project, there is also a video link on the main page. Ultimately, you only need a neon bulb and a business card sized PCB with exposed traces to get this working. Please message if you would like more details. Otherwise, enjoy the content linked throughout this page.
Umm, not likely to have enough current to generate visible light. You will probably need a small battery and high-impedance amplification for this to work.
I was fairly certain that this would not work. I still wanted to try! ;)
