IMU-based oscillations measurement device
Reconstruct oscillations of a tilting object by attaching the device to the object itself
0 followers
IMU-based oscillations measurement device capable of reconstructing the oscillations of a tilting object based on acceleration data sampled from IMU.
Made of an MPU-6050 6 axis IMu, an ESP-8266 D1 mini, a DF player, 8 ohm 2 watt speaker, TP4056 based Battery circuit, 2000 mA Li-Po battery, a VPS and a Button.
The node will capture oscillatory data and transmit this information via Wi-Fi (or eventually Ethernet) to an online server. The data, after acquisition, is transmitted through Wi-Fi using MQTT, an IoT protocol based on
TCP. A broker, in our case Mosquitto, is installed on the VPS (a free online broker can be utilized
for testing purposes). Grafana serves as a subscriber to the MQTT topics, allowing for real-time
visualization of the acquired data through various plots. Additionally, Telegraf acts as another
subscriber, pushing all data to an Influx DB database for long-term stor
JPEG Image - 841.88 kB - 06/13/2024 at 13:31
Preview
JPEG Image - 1.19 MB - 06/13/2024 at 13:31
Preview
Portable Network Graphics (PNG) - 336.85 kB - 06/13/2024 at 13:31
Preview
JPEG Image - 864.69 kB - 06/13/2024 at 13:31
Preview
JPEG Image - 798.58 kB - 06/13/2024 at 13:31
Preview
View all 16 files
  • 1 × MPU-6050 6axis IMU
  • 1 × ESP-8266 D1 MINI
  • 1 × 8ohm 2 watt Speaker
  • 1 × TP4056 battery circuit
  • 1 × 2000 mA Li-Po battery
View all 7 components
