PCB design used the kimotor (https://github.com/cooked/kimotor) KiCad plugin to make quick work of coil layout to fit in the card outline. Going cheap with 2 layer board. The rest is just rectifier and LEDs. Made another board iteration with a reed switch footprints to maybe switch the LEDs on and off with the magnets...
Boards ordered and will hopefully arrive with a few days before contest entry deadline
mulcmu
