Prototyping area - 2.54mm (100mil)
Central area of the ProtoArduPiSHIELD it is a prototyping area with plated through hole with standard raster 2.54mm (100mil) to allowed you to place IC like a opamp, comparator, microcontroler and other type of component like a resistor, transistor, sensors which you usualy used to use in your prototype.
Arduino MEGA and Raspberry Pi
Ground with easy connection to prototyping pins
One of the great things which simplify your design is that you can directly connect pin to the Ground without any additional wire. Basically this mean less mess on your prototype.
Bottom side of ProtoArduPiSHIELD the is flood over with copper plane connected to the GND (ground signal) and it is divided for 4 pins range around dot not covered by solder mask.
Just solder desired pin with dot, and done.
Those two fact give ability to easy connection each pin on the prototyping area to GND signal when you needed.
From another side to make soldering easy if you solder pin from opposite side then GND dot you will avoid random shortcut with GND point.
This shield make your prototype more manageable then ever before - less wire to the the ground.
Silkscreen description
You can easly find a name of each pin whether it is Arduino or Raspberry Pi.
You don't have to look in to documentation especialy when you are making prototyping with Raspberry Pi because pins are not supported with silkscreen on original boards.
An additional
row of pins
An additional row of pins area of pins that you can use to make additional connections.
Proto ArduPiSHIELD have additional rows of the pins for Raspberry Pi as well for Arduino.
Universal SMD packages 0402, 0603, 0805, 1206
Around whole design on the bottom site of the Proto ArduPiSHIELD there are place for SMD packages (0402, 0603, 0805, 1206).
Those footprints allowed you to use SMD components in your prototype, and easy connect them with prototyping area.
Time to time it is not possible to use other type of components then just SMD, or just simply you don't have THT on your stock.
There are also universal solder pads around shield, which can be also used like a place for diferrent type of SMD components.
Also with little bit soldering skills you can also used SMD components on throu hole area.
ProtoArduPiSHIELD compatible with ArduSHIELD
If you already have ArduSHIELD you can
gather all benefint from it with ProtoArduPiSHIELD, and you can still
use your Arduino Uno, Mini, Micro, Nano, Pro Mini, Zero and much more
compatible bords which out there created by great Arduino Community
of people.
Standard Arduino ISCP connector avaliable
GND and +5V is connected to connector. Other signals are not connected due ot diferent connection assigments for Arduino UNO and Arduino Mega. You can still use ProtoArduPiSHIELD for UNO with your Arduino MEGA
Full description of pins for Arduino Mega.
If you are experimenting with Arduino MEGA, you probably noticed that part of the pins are not described on it.
With ProtoArduPiSHIELD you will clearly know which pin is where.
Status LED
On the ProtoArduPiSHIELD ther is a place for power status LED, Which give you indiation that you are connected to power supply when you are testing your prototype.
Hi there, what a nice project. Btw i'm in production for my open source project #ALio : New Hardware Prototyping Platform. It can fit almost all SMD footprint, SOIC, SOP, SO, etc. If you are interested to use my designed, i will publish my footprint once i get the board, to make sure it is compact and there is no revision needed.
