We start the battery board assembly by adding solder paste to each component pad.
Next, we pick and place all the SMD components in their places using an ESD tweezer.
We set the PCB on our DIY REFLOW hotplate to heat it up to the temperature at which solder paste melts. Solder paste melts when the PCB reaches the melting temperature, and components are connected to their pads.
Next, we use a soldering iron to attach the SMD Li-ion Cell Holders from the bottom side.
At last, we added the Li-ion cells in their holders in the right polarity.
The circuit is now complete
2
Battery Board Dual Assembly
After creating two distinct battery pack boards, we need to connect them together to create a single battery pack setup. This is done by sandwiching the two boards with 45-mm-long M3 PCB standoffs.
Using four M3 bolts, we first install four standoffs on a single battery board.
The second board is then mounted using the extended PCB standoffs and four more M3 standoffs.
The end result will be a battery pack circuit made up of two separate boards connected by PCB standoffs.
3
Battery Section Assembly
The battery circuit is now positioned within the battery section part and fastened there with four M3 bolts.
The switches from both circuits are then unsoldered, and they are attached to the switch slots on the battery section part.
We reconnect both switches to the circuits.
In addition, we added a DC barrel jack to the battery section and connected it to the battery board's CON2 charging port using two wires. In order for both battery board circuits to be charged when the charger is plugged in, we additionally connect the CON2 charging ports of both circuits in parallel.
4
Adding the Mid Part with the Battery Section
After assembling the battery section, we placed the midsection on top of it and fastened them both together with four M2 screws.
5
Raspberry Pi Holder Section
The Raspberry Pi is now positioned in its place on the Pi holder part and is secured using four M3 bolts.
Pi holder section assembly is now complete.
6
Battery Section and Raspberry Pi Holder Section Assembly
Next, we linked the lower end of the battery section to the previously built RGB LED board or base.
We begin by connecting the RGB LED board's positive and negative terminals to the 5V and GND terminals on the battery board.
The base is then positioned in its proper location and fastened there with four M2 screws.
7
Top Section Assembly
Threaded inserts are required in order to mount the handle in its proper location on the top part.
All sizes of bits for threaded inserts are included in this TS100 TIP Adaptor Kit that we obtained from PCBWAY Giftshop.
We utilize our Hakko soldering iron and the supplied T18-B alternative bit, which we pair with an M3-size bit.
Subsequently, the threaded insert is picked and positioned over the hole on the top section. The insert is then pushed downward using the soldering iron, causing it to heat up and slide into place.
As much as possible, keep the temperature set below 180°C and above 100°C.
The threaded inserts are added to their places, and we repeat the process for the other side of the top section.
Now that the handle is in the correct spot, we mount it securely using two M3 bolts.
8
Top Assembly Final
This time, the top portion is placed over the Pi holder assembly and fastened in place with four M2 screws.
9
Final Touches: Adding Name Tags
Using four M2 screws, we first attached the Power Pi Version 2 nametag to the device.
The XO name tag is then inserted into the battery section and fastened using M2 screws.
Finally, we used super glue to attach the Arasaka logo to the Pi Holder body.
10
Result
Here's the result of this slightly larger but simple build: a functional Raspberry Pi computer with a built-in battery pack and a cyber-like aesthetic.
Since the Raspberry Pi 4 powers this setup, it can manage almost everything we throw at it, including the old games we intend to run on it.
Here's a fun thing: A web application can control the RGB board color, so all we have to do to control lighting is use a Raspberry Pi or any other external device to access the web application by utilizing the ESP8266 IP address.
Check out the previously built RGB LED board project here.
