Well, Learning Eagle/Fusion Electronic Design on this one. Moving up from Fritzing. First Board turned out meh.. I need to spec bigger pads, and bigger traces. However V0.4 should be good enough to test.
Plan from here is to test on the V0.4 board. Produce sample Code. Refine the Board, and send it off to get produced with nice everything..
Already have forward Kinematic Transforms done. In additon to the board design which I hope others can use for CNC and other 3 Stepper with LCD and SD Card (and some buttons, etc..) Projects...
mperino
SimonXi
Machinehum (Ryan Walker)
Mirko
Serge.V
