RP2040 RP2350 M.2 Pico
A RPI Pico RP2040 and RP2350A board in a M.2 AE key form factor.
Starting from
has orders / reviews
Ships from
I sell on Tindie (https://www.tindie.com/products/pier42/pico2-m2/)
I sell on Lectronz (https://lectronz.com/products/p42-pico2-m-2)
A RPi Pico RP2350A microcontroller board in m.2 3024 size form factor with A and E key. The m.2 interface has USB, UART, I2C and control IO connectivity. Voltage levels for the m.2 specification are obeyed as some of the interfaces run on 1.8 V. Externally +3.3 V, GND, the SWD interface and 16 IOs are accessible on castellated pins. A footprint for a QWIIC connector is on the top side of the board. Power rail LEDs and a user controlled LED are on board, as well as a solder bridge for configuration options. Bottom side has a micro-SD card slot for data storage.
Full list of features:
- M.2 2230-D5-AE card (22 mm x 30 mm; D5 = 1.5mm on top and bottom side violated by the QWIIC connector and the bottom SD card holder; A and E key)
- Used interfaces on the M.2: USB, UART, I2C, ALERT, WAKE, DISABLE1/2, LED 1/2, VENDOR_DEFINED
- 1.8V regulator for level-shifters
- Power LEDs for 3.3 V and 1.1 V
- RP2040/RP2350 peripherals: 2 MB Flash, SWD debug access, RESET and BOOTSEL button, QWIIC connector, 1 LED, 1 solder bridge for config, 9 GPIOs on castellated pins
- castellated pins on 25.4 mm/0.1" raster (almost with a 22 mm board)
- optional uSD card holder on the bottom side
- optional pull-down resistors on castellated IOs to mitigate the E9 Erratum
- sample application programmed in Arduino it available. It has a command line interface through the USB/UART and exercises all the ports.
P42 M.2 Pico2 (rev3) Documentation V0.1.pdf
User manual
Adobe Portable Document Format - 1.46 MB - 05/31/2025 at 23:58
Preview
SCH P42-Pico_Mdot2_r3.pdf
Schematic current version
Adobe Portable Document Format - 631.75 kB - 05/31/2025 at 23:58
Preview
M.2 pinout Overview.pdf
Table of M.2 pin functions and specification
Adobe Portable Document Format - 36.58 kB - 02/28/2025 at 03:14
Preview
  • 1 × RP2350 RPi Pico2 MCU
  • 1 × W25Q16 16Mbit QSPI Flash
  • 1 × Molex 104031-0811 MicroSD card holder
  • New test platform
    MagicWolfi06/01/2025 at 23:17 0 comments
    I have assembled rev2 of my Simple M.2 Carrier, which is a useful test platform for the Pico2 M.2 board.
    It breaks out all pin of the M.2 connector to TH test pads and specially the I2C and UART interfaces to connectors with level shifters back to a more useful 3.3V level.
    The setup shows a TTL USB-UART connected, a simple EEPROM on the carrier I2C interface and a LSM9DS1 board on the internal I2C QWIIC connector. All attached devices are communicating as planned.
    The carrier could also mount a 2442/3042 sized M.2 board, just the mounting standoff is still missing.
  • Sample application - Command Line Interface
    MagicWolfi03/31/2025 at 01:15 0 comments
    Here are some screenshots of the CLI in action.
  • Pinout and port mapping
    MagicWolfi03/30/2025 at 01:27 0 comments
    Everything is working now and here are the pin and port access details.
  • Pico2 Rev2
    MagicWolfi02/16/2025 at 20:26 0 comments
    Just received revision 2 of the board!
    This time I went for real castellated holes on 3 sides, even though JLC charges an arm (pun intended) and a leg for it.
    The 2nd big change is the switch to the RP2350, if you counted the pins. I was lucky to get into their samples program and have some RP2350A and B (including Flash and crystals) at my desk. Some soldering required.
    Here is a nice view of the board and the castellated holes detail. Test firmware is running on a Pico2 already.
    And some hot air soldering later, the board looks like this and is operational. SD card is alive, UART to the M.2 interface and all GPIOs. Still missing the QWIIC connector and a SC70 p-FET for the core voltage LED. Also the design decision to use an external LDO instead of the internal switcher for the 1.1 V core supply has proven to be good and will make the BOM cost being less.
  • SPI1 SD card success
    MagicWolfi01/25/2025 at 02:49 0 comments
    Documentation update
    SPI1 is working with the following hardware setup:
    #defineGPWireSD Adapter
    SD card pin
    SD_CS
    13greenD32
    SD_DI12blackD07
    SD_DO11blueCMD3
    SD_CLK10greyCK5
    This was more difficult than it should be, but finally it is done.
    SDcard test.
    Writing to test.txt...done.
    test.txt:
    1161011151161051101033249443250443251461310
    SD Card Speed Test...
    Writing to byte.txt...done.
    Duration [millisec]: 8250
    FileSize [bytes]: 1048576
    Write Speed(8bit) [KByte/sec]: 128
    Writing to 16bit.txt...done.
    Duration [millisec]: 13657
    FileSize [bytes]: 2097152
    Write Speed(16bit) [KByte/sec]: 157
    Writing to 32bit.txt...done.
    Duration [millisec]: 23569
    FileSize [bytes]: 4194304
    Write Speed(32bit) [KByte/sec]: 178
    done.
    >d
    SDcard root directory.
    System Volume Information/
            IndexerVolumeGuid               76      CREATION: 2024-12-20 22:24:20   LAST WRITE: 2024-12-20 22:24:22
            WPSettings.dat          12      CREATION: 2024-12-20 22:24:40   LAST WRITE: 2024-12-20 22:24:42
    test.txt                18      CREATION: 2098-01-01 00:00:12   LAST WRITE: 2098-01-01 00:00:42
    byte.txt                1048576 CREATION: 2098-01-01 00:00:42   LAST WRITE: 2098-01-01 00:00:58
    16bit.txt               2097152 CREATION: 2098-01-01 00:00:58   LAST WRITE: 2098-01-01 00:01:22
    32bit.txt               4194304 CREATION: 2098-01-01 00:01:22   LAST WRITE: 2098-01-01 00:01:12
    >uSD Card removed!
    And here is the instruction to fix the traces before putting on the uSD holder to hide the mod:
  • SD Card success
    MagicWolfi01/13/2025 at 02:04 0 comments
    For whatever reason (which I will find out later) I could not make the SD card work on the SPI1 port of the RPi Pico with (CS=GPIO13, CLK=GPIO10, MOSI=GPIO11, MISO=GPIO12).
    So I did some re-wiring and used the standard SPI port with the pin mapping as follows:
    #define SD_CS         17
    #define SD_DI         16
    #define SD_DO         19
    #define SD_CLK        18
    // uSD card
    SPI.setRX(SD_DI);
    SPI.setCS(SD_CS);
    SPI.setSCK(SD_CLK);
    SPI.setTX(SD_DO );
     This approach worked flawlessly and I could do all the file system commands provided by the SD.h library.
    A simple speed test did show sufficient performance for basic data logging:
    Duration [millisec]: 10377
    Write Speed(8bit) [KByte/sec]: 102
    Duration [millisec]: 15828
    Write Speed(16bit) [KByte/sec]: 136
    Duration [millisec]: 28910
    Write Speed(32bit) [KByte/sec]: 146
    done
    The write speed vary for the 8bit test from 97 to 128 KB/sec and for the 16bit test from 120 to 136 KB/sec. The 32bit test is very stable at 146 KB/sec.
  • Micro SD card shenanigans
    MagicWolfi12/01/2024 at 02:42 0 comments
    As mentioned earlier, the SPI interface signals of the uSD card slot are connected backwards.
    SCK <-> CSn
    MOSI <-> MISO
    This means 4 cut traces and 4 wires. In the end nobody will know because the wires will be hidden under the SD card holder. Just a few pictures to document the process:
    Cut trances and wires already attached. I used 38 gauge magnet wire, which is perfect for this kind of re-work as the insulation melts away. No wire stripping required.
    Then the wires got nicely covered with Polyimide for protection
    And the uSD card holder soldered to the board.
    Next, a trip into software land and trying to talk to the uSD card. I am going to try the Arduino SD library and [Greiman]'s SdFat library. I learned already that the maximum size for FAT32 file-system is 32GB, everything larger needs to run with exFAT. I will find out soon.
  • Poor-mans version of the castellated pins
    MagicWolfi11/16/2024 at 03:07 0 comments
    Since a long time I had the idea to simulate castellated pins on a board edge to get around the pricey options to do it as intended by your PCB house of least suspicion. My idea was to have the PCB outline indented by half circles and add a curved pad on top and bottom connected through one or more vias. Wires or pin headers could be soldered to either pad. To solder the board on a prepared carrier footprint ( ESP32 module style) would probably need some extra wires, but that was not the intend of this board anyways.
    Here is an image how the 2 pad styles look in KiCAD (please ignore the silkscreen, this layout was far from finished). I probably could have moved the half pad closer to the board edge.
     After receiving the boards, I tried to solder pin headers to the pads and ran into several problems. The board was only 0.8mm thick, so there was not much support. With the plastic body on one side, I did solder only the opposite pad to the pin which did not give enough strength. I tried to use hot glue to fix the connector to the board but still managed to rip off pads very easily. Some more pictures of the whole mess.
    Overall it was more pain than useful. I would give this idea a -1 out of 11, would not recommend.
  • Current state of Integration
    MagicWolfi11/07/2024 at 02:39 0 comments
    As it happens too often, this revision 1 board has its issues. With my RadXA ROCK 3A SBC not arrived yet, I was going for the fly-wire test approach.
    USB and power through an external 3.3 V regulator are working flawlessly. Power LEDs are on and the user LED is blinking away. Nice! UART on the m.2 and on GPIOs are doing simple loopback and the USB/UART is running a simple command line already.
    Things that did not work out of the box: I2C (of course). I should pay more attention to the pin mapping. I cannot use I2C1 at the same time on the m.2 and the QWIIC connector. Also pin4 on the QWIIC is SCL, not SDA. Nothing a few cuts and wires cannot fix. Now I have a loop-back from the m.2 end to the QWIIC connector. One port is master, one is slave. Mint.
    More wires will be required to test the uSD card, the SPI signals are connected up-sidedown to the SPI port on the RP2040. Pin mapping again! I blame this one on the schematic symbol, not showing all pin functions.
    And the castellated holes will get their own log. Some cheap ideas are also bad.
View all 9 project logs
Pranav Nayak wrote 11/13/2024 at 07:48 point
If I may ask, what is the inspiration behind building this configuration of the Pico
MagicWolfi wrote 11/17/2024 at 03:33 point
I wanted to design a Pico board in a new form factor, not just square with castellated edges. Initially I was looking at a M.2 PicoW as a lot of laptops use m.2 E-key Wifi cards, but the certification overhead to be able to sell it legally, kept me from doing it. So I did a regular RP2040 board.
There still might be a PicoW 2 in the future if they decide to upgrade the Wifi module.
Loguicx wrote 11/05/2024 at 23:14 point
I'm the kind of person who's bothered by the thought of an empty and unused E-Key socket on their motherboard 😆and, while I haven't yet found a solid reason for using such a board, this is a great design.
The interfaces present in the a E-Key pinout are, apart from PCIe, the ones featured in most microcontrollers so the RP2040 seems the right choice.
SPI is mentioned in the description of this project but, as far as I know, there is no SPI on an A- or E-Key M.2 socket 🤔
Would the RP2040 be able to sniff the traffic on the I2C/SMB bus? There doesn't seem to be much information at all about what's exchanged on such bus (it doesn't seem to be standardised among manufacturers) and it could be that there are many separated segments of I2C in the same motherboard.
PS: M.2 sockets for Wi-Fi/BT on desktop motherboard are (often?) E-Key. I wonder if there could have been any use for the I2S/PCM interface present on the pins which are where the A-Key notch is.
MagicWolfi wrote 11/07/2024 at 01:40 point
Thanks. Oh, you are correct, there is no SPI going to the m.2 interface. Looks like I mixed the SD-card interface together with another (undocumented) project that is going to be a m.2 carrier board connecting the SDIO from the E-key spec to a uC. I was hoping to make the SPI port talk SDIO.
The RP2040 should be able to sniff I2C traffic. Making those pins simple inputs and having a clever edge detect logic might do the trick. You could have a look at the BusPirate 5 firmware. Rev5.3+ does include a sniffer, but only up to 100 Kbaud.
Adding more than one key notch is always a compromise.
Loguicx wrote 11/20/2024 at 00:32 point
Thanks.
When I think of the intended use of a board in M.2 form factor I think of something internal to a PC (laptop or desktop) with the option to reach the outside via (a limited number of) cables. In the case of the RP2040 M.2 Pico I would prioritise tasks which rely on the interfaces in the A+E key as the real estate for connectors is extremely limited.
If I understood your intent, the castellation seem to point towards the installation of the board in an environment different from the M.2 slot, as a module mounted on a carrier board. It seems that supporting both environment is very very hard to pull off successfully.
Apologies for coming and debating your extraordinary work, but have you thought of a different arrangement in which there are no castellations, all components <1.5mm are on the side towards the motherboard (bottom side) and on the top you have the tactile pushbuttons, LEDs (?), the SMD uSD receptacle and the footprint od SMD headers, with a relatively small pitch like 2mm or smaller? The pins of the RP2040 would be exposed on those headers (which obviously would violate the 1.5mm constraint).
arturo182 wrote 11/04/2024 at 19:28 point
You might have some notes to exchange with @timonsku :D https://twitter.com/timonsku/status/1376209933381816324
MagicWolfi wrote 11/07/2024 at 01:25 point
Yes, I know about this board. Very similar concept but why a B-key?
I was going to add more information to the project, but HaD was too quick making an article out of my basic write-up.
Ralf wrote 05/02/2025 at 16:12 point
Well, the B-key, so you can use it in a WWAN-slot... actually... looking at your design... erm... I mean you could just cut out A+B+E and confidently violate the PCI-SIG/M.2 Specs, so that it would fit in both WLAN+WWAN-slots, right? O:-)
