For whatever reason (which I will find out later) I could not make the SD card work on the SPI1 port of the RPi Pico with (CS=GPIO13, CLK=GPIO10, MOSI=GPIO11, MISO=GPIO12).
So I did some re-wiring and used the standard SPI port with the pin mapping as follows:
#define SD_CS 17
#define SD_DI 16
#define SD_DO 19
#define SD_CLK 18
// uSD card
SPI.setRX(SD_DI);
SPI.setCS(SD_CS);
SPI.setSCK(SD_CLK);
SPI.setTX(SD_DO );
This approach worked flawlessly and I could do all the file system commands provided by the SD.h library.
A simple speed test did show sufficient performance for basic data logging:
SD Card Speed Test... Writing to byte.txt...done. Duration [millisec]: 10377 FileSize [bytes]: 1048576 Write Speed(8bit) [KByte/sec]: 102 Writing to 16bit.txt...done. Duration [millisec]: 15828 FileSize [bytes]: 2097152 Write Speed(16bit) [KByte/sec]: 136 Writing to 32bit.txt...done. Duration [millisec]: 28910 FileSize [bytes]: 4194304 Write Speed(32bit) [KByte/sec]: 146 done
The write speed vary for the 8bit test from 97 to 128 KB/sec and for the 16bit test from 120 to 136 KB/sec. The 32bit test is very stable at 146 KB/sec.
MagicWolfi
