Naive Business Card
Learning PCB Design by creating a simple business card with LEDs whose blinking frequency is adjustable.
In my journey of learning Electronics and PCB design, and with the philosophy “fail fast, fail often” in mind, I wanted to challenge myself with the Hackaday's 2024 Business Card Challenge. I created a very simple business card with a couple of LEDs whose blinking frequency can be adjusted by a trimmer.
Project repository: https://github.com/lorenzopalloni/naive-business-card/
I used KiCad 8.0.
Among others, I want to thank Shawn Hymel, Philip Salmony (Phil's Lab), and Charles Platt, from whom I have learnt a ton.
- KiCad Tutorial, by Shawn Hymel: https://www.youtube.com/playlist?list=PL3bNyZYHcRSUhUXUt51W6nKvxx2ORvUQB
- KiCad 7 STM32 Bluetooth Hardware Design (1/2 Schematic), by Phil's Lab: https://www.youtube.com/watch?v=nkHFoxe0mrU
- Make: Electronics: Learn by Discovery, by Charles Platt: https://www.amazon.it/Make-Electronics-Learning-Through-Discovery/dp/0596153740
The business card features two LEDs whose blinking frequency can be adjusted using a trimmer. This project was designed using KiCad 8.0.
Project Repository: https://github.com/lorenzopalloni/naive-business-card/
  • I cannot believe it actually works! O.o
    Lorenzo Palloni07/16/2024 at 12:30 0 comments
    I ordered only 5 PCBs, because I wasn't 100% sure they would work. My main concern was the thickness of about 1 mm. Eventually, soldering was easier than expected. Though I fried the first one after almost 2 hours of soldering, the second try actually worked out pretty well and only took me half an hour this time.
    I received my custom PCBs after a couple of weeks after ordering them from PCBWay.
    I took another shot, tuning some parameters of my Samsung s23 Ultra's camera in Manual Mode. Surprised by the quality change, I wanted to show the difference.
    This is the one I fried.
    While the second one, after a bit of troubleshooting, turned on!
    I also did a short video demo, which I put on YouTube and in the project details here on Hackaday.
  • I ordered my first PCB! :D
    Lorenzo Palloni06/29/2024 at 13:59 0 comments
    It's official, I placed the order on PCBWay!
    I'm eager to see if the board will work. 😬
    The cost was pretty low: $6.5, and with a discount coupon, it was just $1.5. Including shipping, I paid about $10.0.
    I chose a thickness of 1.0 mm instead of the default 1.6 mm. The cost was the same, but I'm worried that the PTH components might be too heavy for the thinner board.
  • How it started
    Lorenzo Palloni06/29/2024 at 13:25 0 comments
    At the beginning, I started outlining the business card in my e-paper tablet, using a ruler to understand the actual size.
    I wanted to stay simple with the electronics involved because I'm quite a newbie in this field. So, I thought about combining a couple of examples I saw in the book “Make: Electronics” by Charles Platt and the Shawn Hymel's tutorial on KiCad. Eventually, I came up with the following circuit on a breadboard. Not just any breadboard, but the Ben Eater's favourite: the BB830. :)
    Some components needed to be measured carefully. So, with some datasheets at hand, I spent quite some time figuring out the exact sizes.
    Ah, this is how the board looked in the KiCad 3D viewer:
View all 3 project logs
