Installing the script on your Raspberry Pi
07/19/2014 at 17:15 • 0 commentsThere are many flavors of Linux available for the Raspberry Pi, so I will focus on the generic Raspbian build as well as one for Arch Linux. Why Arch? I am using MinePeon in my Bitcoin mining rig!
Raspian:
First, install git if you haven't already:
sudo apt-get update
sudo apt-get upgrade
sudo apt-get install git-core
Download wiringPi and install it:
git clone git://git.drogon.net/wiringPi
cd wiringPi
./build
Create the shutdowncheck script:
cd ~
sudo nano shutdowncheck
Type the following into the nano text editor:
#!/bin/bash
PATH=/usr/bin:/home/pi/wiringPi/gpio
echo "Shutdown script starting..."
echo "Asserting pins (7=in, low(pull-down); 8=out,high)"
gpio -g mode 7 in
gpio -g mode 7 down
gpio -g write 7 0
gpio -g mode 8 out
gpio -g write 8 1
COUNTER=0
while [ 1 ]; do
if [ "$(/home/pi/wiringPi/gpio/gpio -g read 7)" = "1" ]; then
echo "PIN7 requested a SYSTEM HALT!"
sudo halt -p
break
fi
sudo sleep 0.5
done
exit 0After you have typed this in and double checked your work, press ctrl-o (to save) and ctrl-x (to exit).
Next, make the script executable:
sudo chmod 755 shutdowncheck
Why type? Why can't I just pull it from your github? Because you can learn a bit about how gpio works on your pi by typing it manually. Also, some distros interpret new lines differently and you may end up with a non functioning script.
Edit your /etc/rc.local file and add the following line before the last line (exit 0):
sudo nano /etc/rc.local
Add this line before exit 0:
(cd /home/pi && exec ./shutdowncheck) &
Save (ctrl-o) and exit nano (ctrl-x). Now your script will run automatically when your Pi starts up!
Arch Linux (MinePeon specific instructions)
Special thanks to synapseattack from bitcointalk.org for the MinePeon instructions!
cd wiringPi
./build
sudo cp /home/minepeon/wiringPi/gpio/gpio /usr/bin/
sudo nano /usr/bin/shutdowncheck
Type the following into nano and then hit ctrl-o (save) and then ctrl-x (exit):
#!/bin/bash
PATH=/usr/bin
gpio -g mode 7 in
gpio -g mode 7 down
gpio -g write 7 0
gpio -g mode 8 out
gpio -g write 8 1
COUNTER=0
while [ 1 ]; do
if [ "$(/usr/bin/gpio -g read 7)" = "1" ]; then
sudo halt -p
break
fi
sudo sleep 0.5
done
exit 0Make the new file executable:
sudo chmod +x /usr/bin/shutdowncheck
Now make it a service:
sudo nano /usr/lib/systemd/system/shutdowncheck.service
Type this into nano (ctrl-o and ctrl-x to save and exit):
[Unit]
Description=ShutdownCheck
ConditionFileIsExecutable=/usr/bin/shutdowncheck
[Service]
Type=forking
ExecStart=/usr/bin/shutdowncheck
TimeoutSec=0
StandardOutput=tty
RemainAfterExit=yes
SysVStartPriority=99
[Install]
WantedBy=multi-user.targetNow enable your new service:
sudo systemctl enable shutdowncheck.service
Now your script will run during boot (you will need to reboot after enabling the service).
