As the first two methods did show any significant improvement it was time for something more aggressive.
NITRIC ACID!
As I don't want to buy nor own Nitric acid. I went and bought Potassium nitrate.
Potassium nitrate is a powder with granularity similar to sugar. I've used tiny twizers to add amount which will be 1/3 of space I have there.
![](https://cdn.hackaday.io/images/7905191719714870580.jpg)
Once added one drop of sulfuric acid, potassium nitrate powder quickly dissolved and got this opaque substance.
![](https://cdn.hackaday.io/images/7740951719715339726.jpg)
I've placed the IC inside airtight jar and let it sit for one hour.
I've clean the drop with water (not sure if this the right thing to do, maybe I should use acetone) the first impression was that nothing really happened. On the microscopic level we got a totally different picture.
![](https://cdn.hackaday.io/images/3102781719715568893.jpg)
On the top picture we can see the lines/scratches of Dremel bit. On the bottom picture we can see those lines are gone and all the surface was mildly eaten by acid.
Although I didn't get all the silicone revealed it's a first step in the right direction.
Next thing would be adding heating element that could change temperature room temperature to about 220°c. Once we have this setup we can play around and see which temperature is minimal for epoxy removal.
