Method #11 - FAIL
A project log for Safe IC decapping while preserving bond wires
Decapping using hardware store available materials and relatively safe procedure
100dollarhacker100dollarhacker 08/01/2024 at 19:400 Comments
I've tried to use higher temperatures of 260°c for short time of 2-3 minutes. It was late at night and it didn't occur to me to check Fuming Nitric acid boiling temperature which is only 83°c. (Concentrated boiling point is 120°c) Basically I've vaporized all Nitric acid before it could do anything.
