Initial Coding & Electronics
A project log for Swirl Dice
A Moving Magnet based Dice Roller
andrew-woodbridgeAndrew Woodbridge 07/06/2024 at 04:330 Comments
The initial code is setup. There are three modes:
Random Number Generation is currently accomplished by combining amount and distance values from the magnetometer then moded by the number of sides. This method will require further testing for randomness.
