So called "Ashtray compute"
07/13/2024 at 07:13 • 0 commentsThere I was... it hit me... like a dream
I bought some gold PLA... this probably will not look good but the idea is... you put the quadlidar setup in an ashtray deal solid plastic and then it's like a NUC box... future... if I get VIMU keeb fully working, it has a popout camera for keyboard... so then you have this box computer thing that doesn't use a mouse or a keyboard.
Quadlidar
07/11/2024 at 05:35 • 0 commentsThat's right... that means 4
It's slow... probably the 4 x 20 ms minimum sampling rate and the pyautogui calls
I probably won't put much more time into this project... it's not ergonomic... I may look into the software more since it's pretty janky, I only spent a day on this
Problems and progress
07/04/2024 at 01:35 • 0 commentsI did get it to be where it's just code and math now
See a vague demo of how it works
and then the pain I went through to get there ha
Some design work (Trilidar mouse)
07/01/2024 at 19:41 • 0 commentsPronounced "try-lid-ar" heh
I'm largely basing everything off the VL53L0X's beam pattern (25-30 deg) and that I'm using 3 of them.
I ordered some more... although I may use the different brands to get a difference I2C address vs. using say SPI or a microcontroller between the sensors/pi.
Will print tomorrow/do wiring and program testing.
I'm hoping there are no obvious gotchas that make this not work.
I initially thought 25-30 deg is massive but it's not... you still need a large diameter ring. The effective area I'm looking at with a 6" outer ring is a 2.5" inner ring (based on dead zones).
Why
06/29/2024 at 23:15 • 0 commentsI'm giving away my daily driver laptop to a friend. It's nothing crazy a 2015 i7 Macbook Pro. Anyway I wanted to daily drive an RPi 4 as a basic browser/linux machine.
I have had this 8GB model lying around so I decided now is the time to use it.
The trilidar mouse thing is funny, I was like "oh I don't have a spare mouse"... I could make one.
Mostly I don't like the idea of a loose mouse you gotta keep track of.
What sucks with this project is there isn't a power bus bridge thing (y-splitter USB cable) but I'll look into that.
The mouse is honestly the coolest part of the project since it has to work as a mouse somehow and I'll have to look into that.
I'll work on this after tomorrow (Sunday) since I'll have some days off then.
I bought this keyboard but I never really liked it. The sideways profile is like an n-shape which is weird, it should be a u IMO.
But I like the keycap color and sound/thickness of the caps.
These sensors the purple Pololu VL53L0X have a really wide cone... that's what I'm counting on here.
It's possible the accuracy is just bad but I'm thinking the triangle part... the pulsing would be done in a sequence so the beams don't hit each other/trip the receiving end.
Jacob David C Cunningham
