1Step 1
A step by step through some images.
These are the components to use -
2Step 2
Here we can see the inside of the power supply and how the arduino plate has been mounted using a piece of wood as an insulator
3Step 3
Here we can see the mega arduino board mounted and you can also see the cables of the power supply for which a new hole has been made to come out to the outside by the top.
4Step 4
This is the LCD smart controller, we can see the brackets with which it will be attached to the front panel. -
5Step 5
The inside view
6Step 6
Here we can see the LCD smart controller and also the assembly of the fan to cool the drivers for stepper motors.
7Step 7
I did not have the fan grill and I put a piece of wire mesh I found in the workshop.
8Step 8
Here we can see the left side panel with the holes to mount the connectors. And at the top we can see the welded connectors on a universal printed circuit board
9Step 9
Here we see how we fixed it with screws.
10Step 10
Below are several views of the final assembly.
jvsalatino
