1Creating your own PixelCard
By building this project, you can create your own personalized electronic business card. You will be able to:
- Change the text displayed on the card.
- Advanced changes:
- Modify the layout of the business card (e.g., component placement).
- Add more or different components and features to the card.
2Setup Tools
Install KiCad 8
Follow the official KiCad installation guide for your operating system.
Install Poetry
Ensure you have Python installed.
Install poetry (a tool for dependency management and packaging in Python)
Clone the Repository
Clone the GitHub PixelCard repository or download the zip (and unzip it)
git clone https://github.com/ruben-iteng/PixelCard.git
and open the project folder
cd PixelCard
Set Up the Project Environment
Run the following commands in the repository folder to setup a local environment and install the dependencies in there:
poetry shell poetry instal
Test if it works
python ./src/pixelcard/main.py --help
You are now ready to change and build your customized version of the PixelCard!
3Changing the Text on the Card and Generating Manufacturing Files
To change the text on the card and generate the necessary manufacturing files, use the following command:
python ./src/pixelcard/main.py 'Hack' 'Name: ABC\nTel:1234'
You will be able to find all the files you need to order your card in the /build folder.
Of course you can change "Hello World" to any text you like, but pay attention that you have very limited space on a credit card sized PCB!
4Checking your design in KiCad
You can optionally check your design in KiCad PCB Edditor (Standalone).
Just open KiCad PCB Edditor and open the main.kicad_pcb file in the source folder
