Demo #3 Enable/Disable 3.3 V Outputs
A project log for ESP32-S3 PowerFeather
Low-power, Feather-format ESP32 dev board for LiPo/Li-Ion and solar powered IoT projects
powerfeatherdevpowerfeatherdev 07/14/2024 at 12:590 Comments
The board's two 3.3 V outputs (3.3 V header pin output & STEMMA QT 3.3 V output) can be enabled/disabled independently for power saving.In the photos below, the red LED is powered from the header pin 3.3 V output, and the STEMMA QT module from the STEMMA QT 3.3 V output. Switching on/off the controls on the dashboard, these two devices turn on/off accordingly:
Header pin 3.3 V output enabled, red LED on
Header pin 3.3 V output disabled, red LED off
STEMMA QT 3.3 V output disabled, green LED on STEMMA QT module on
STEMMA QT 3.3 V output disabled, green LED on STEMMA QT module off
