The goal for this test was to verify that the overvoltage and undervoltage protection limits for the energy harvesting subsystem are hitting their intended set points.
Result: PASS
| Test | Expected [V] | Observed [V] | Error [%] |
| Overvoltage | 4.133 | 4.15 | -0.4% |
| Undervoltage | 3.040 | 3.06 | -0.6% |
Procedure
To simplify this test I isolated the solar harvester from the system, and provided a relatively small capacitor instead of a LIPO or LIC.
- Isolate Boost Converter: Removed R28 to disconnect the downstream boost circuitry.
- Temporary Storage: Populated a 1000uF capacitor onto the battery pins (J9/J10).
- Power Source: Connected a solar cell to J1.
Overvoltage Limit & Hysteresis
For this capture, I probed Vsolar, Vbat, and the current into Vsolar. (Schematic above)
I was hoping to catch a glimpse of the MPPT (Maximum Power Point Tracking) at work here, but no dice. I suspect with a better light source I’d be able to witness the MPPT in action.
Undervoltage Limit
Using the same setup, I moved the VSOLAR probe to VSTOR to observe the disconnect behavior.
Next Steps
Now that the limits are verified, I can move back to full-system integration and see how these limits hold up under the varied load of the H-bridge pulses. For now I'll be testing with bulk caps in place of a LIPO. In the future these limits will likely be tightened further.
Jesse Farrell
