CONSTRUCTION PROCESS
A project log for "La Carafe"
A swingable user friendly water carafe
sabrinanadersabrinanader 07/08/2024 at 13:200 Comments
The construction process involved several steps. First, we cut with the help of a laser cutter the wooden pieces to the desired shape and size using fusion 360, ensuring they were symmetrical and smooth. We then drilled holes in these wooden pieces where the dowels would be inserted, making sure all holes were correctly aligned to provide stability. Following this, the wooden dowels were inserted into the drilled holes and secured with littke white caps ro make it look more aesthetic.
