YULC (Yes, a USB-C Led Controller)
A Flexible Type-C PD Led Strip Controller
Public Chat
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
YULC is your perfect mate for powering your lightings. Thanks to its compact form factor, it can be placed almost everywhere, it features a lot of protections to ensure safety for both the charger and the strips, and in the meanwhile, can provide a lot of juice to feed very power-hungry lights setup. It also boasts an handy built-in buck regulator that from a maximum of 24V ensures safe 5V or 12V to your output. This mean that is also possible to use 18,19,...,24V external power supply (USB-C or barrel jack) taking advantage of their higher total power output and converting them to 5V or 12V increasing the output current. Furthermore, on the back of the board there is a powerful ESP32-S3, directly programmable from the USB-C, that allows you to manage even more complex effects and to run heavy tasks.
So, in few words, YULC consists in a full-featured board that can replace a lot of wiring messes, optimizing space and debug time in a reliable way.
