Being fully open source, Von VisionAI features a completely integrated hardware design that is not locked into a third-party System-on-Module format. It features a 7-inch 1024x600 90 Hz touchscreen, a 48 MP Sony camera, 4 GB of LPDDR4X SDRAM, 2.4 GHz Wi-Fi connectivity, Gigabit Ethernet, and USB Type-C.
We're also including an ESP32 on our board so you can easily interface the complex and advanced Linux CPU, with the simple and well-known ESP32, so that you can interface with the outside world as easily as you are used to! Any specific object detection or data coming in or out the powerful microprocessor can be easily relayed to the ESP32, from where you can a lot more easily control motors, relay information wirelessly, turn on or off any other device, and anything you can imagine!.
While we initially developed just a CCTV camera, we also developed a portable version with a touchscreen as well for mobile applications! The poweful Mali GPU inside will offload the graphics processing off the CPU.
CCTV version of Von VisionAI powered through PoE
Portable Version. Enclosure not final.
Thanks to its integrated design, Von VisionAI is a great solution for use cases such as:
- Deploy outdoors for Edge AI recognition scenarios, while on battery power
- Install with standard PoE splitters far from power outlets
- Apply real-time machine learning to a high-resolution video feed
- Stream H.264 or H.265 video through RTSP or WebRTC
- Analyze multiple Ethernet cameras' worth of data on one device
Currently we benchmark slightly over 30fps doing AI inference on 1920x1080 video streams. We offload AI to the NPU cores, and we offload rendering to the GPU, leaving the main CPU around 80% free to do any other task. Everything (Schematic + PCB + Firmware) is being released under MIT license.
Real Time AI test recorded from a Von VisionAI prototype
Success Story: We wanted to save lives and reduce accidents on the streets. So we're currently doing test deployments of Von VisionAI (CCTV version) to reduce traffic infractions and violations on real time. We will disclose more about this in due time. This is just one of the infinite use cases of our platform.
Feel free to use them for your own products and ideas! Subscribe to our Crowdsupply pre-campaign if you like it!
https://www.crowdsupply.com/punto-maximo-llc/von-visionai
Also we are opening up our Discourse forums, feel free to join and say hello:
avi448
Eric Wiiliam
TheMarpe
Christopher
