Well, still no luck getting the current PCB up and running with the Teensy. I have decided to try making a new one.
- I improved the oscillator grounding
- I moved things around to make it a little easier to debug
- I have made the SMD pads to the teensy longer to make it easier to do hand touch-up soldering.
The main challenge I think is that I am trying to go straight from breadboarding to miniaturization. This makes it a bit harder to debug, not to mention solder. Right now I am not using a stencil which makes the solder paste application very tedious and error prone. Hopefully these improvements will make it a bit easier. You can find the new board on oshpark here:
Hi, thanks for sharing your project! Unfortunately, the "order from OSH Park" link appears to just go to the image file, not your shared project page.
Thanks, I think I fixed it.
