Communicator_Code_BETA_v2.zip
Beta version of communicator code supporting unlimited nodes. streaming library now inherits original lowPowerLab library. Exact RFM69 library now included to avoid version incompatibility.
Zip Archive - 540.23 kB - 11/27/2017 at 00:35
Download
PacketStreamDemo.zip
A demo of a packet stream instead of a bit stream. This is way more reliable.
Zip Archive - 575.23 kB - 07/01/2017 at 16:55
Download
RFM69_old.zip
Use in place of RFM69 library with Communicator_Code_BETA_v1
Zip Archive - 218.41 kB - 04/04/2017 at 02:20
Download
Communicator_Code_BETA_v1.zip
Beta version of communicator code with two unique nodes. streaming library now inherits original lowPowerLab library.
Zip Archive - 53.08 kB - 03/28/2017 at 00:53
Download
communicator_v2p2.sch
Power switch now controls enable pin of regulator so switch is not in power path.
sch - 292.67 kB - 03/26/2017 at 22:54
Download
communicator_v2p2.brd
brd - 150.95 kB - 03/26/2017 at 22:54
Download
Video_Demo.zip
Code used in demo video. Tested and working with 915MHz Radio
Zip Archive - 12.07 kB - 03/13/2017 at 02:01
Download
RFM69_Stream.zip
RFM69 Library from Low Power Lab, modified to allow audio streaming.
x-zip-compressed - 199.73 kB - 03/06/2017 at 16:49
Download
communicator_v2p1.sch
New board with power switch and tap detector interrupt on deep-sleep enabled pin
sch - 291.75 kB - 03/01/2017 at 05:57
Download
communicator_v2p1.brd
brd - 141.56 kB - 03/01/2017 at 05:56
Download
Unit Tests.zip
Arduino test code for each sub-system , mic, speaker, accelerometer.
Zip Archive - 19.58 kB - 02/27/2017 at 04:25
Download
tng_chirp_clean_32000_u8bit_trimmed.wav
Chirp sound that is played when communication is initiated
Waveform Audio File Format (WAV) - 9.81 kB - 02/27/2017 at 04:00
Download
Communicator_Demo.zip
Arduino demo code that puts one Teensy LC in Audio Transmit mode and another in Audio Receive mode.
Zip Archive - 224.88 kB - 02/21/2017 at 02:53
Download
MOUSER_Invoice_scrubbed.pdf
Detailed Mouser invoice showing exactly what parts to get. Bootloader chip needs to be purchased from PRJC directly.
Adobe Portable Document Format - 852.62 kB - 02/17/2017 at 07:27
Preview
communicator_v2.brd
New Board Layout
brd - 138.53 kB - 02/17/2017 at 07:18
Download
communicator_v2.sch
New Board Schematic
sch - 280.76 kB - 02/17/2017 at 07:18
Download
Bitrate Calculations.xlsx
Spreadsheet of bitrate calculations and achievable bandwidths
sheet - 5.17 kB - 02/03/2017 at 04:40
Download
communicator.sch
Eagle Schematic of Communicator Badge
sch - 280.76 kB - 02/03/2017 at 04:04
Download
communicator.brd
Eagle Layout of Communicator Badge
brd - 134.07 kB - 02/03/2017 at 04:04
Download
