Microphone and Accelerometer Working!
02/24/2017 at 02:55 • 0 commentsHorray! Now that the Teensy issues are solved I have been making super progress!
- The Accelerometer is working. I have it configured as a tap detector. I had to modify some libraries :( which will make code reuse a little pain, but it works!
- The microphone is working better than I expected. Actually, it is so sensitive, it is easy to overdrive it just by yelling while the badge is on your chest. Here's a screenshot of me humming a tone, while looking forward with the badge on my chest.
It's Alive!!!!!!!!!!
02/24/2017 at 01:46 • 0 commentsHooray,
Thanks to some helpful guidance from Paul on the PRJC forum and I found a missing trace on one of the USB lines. I repaired it and am now talking with the Teensy. A huge step forward!
NOTE: the new version of the board does NOT have this mistake.
Next step, start talking with the accelerometer and microphone!
Do you have a good attention to detail?
02/23/2017 at 02:29 • 0 commentsHi Project followers! Do you have a good eye for soldering mistakes? I have posted detailed photos of the current board that is not working.
If you spot a smoking gun I will forever be in gratitude!
Trying a new PCB
02/16/2017 at 05:07 • 2 commentsWell, still no luck getting the current PCB up and running with the Teensy. I have decided to try making a new one.
- I improved the oscillator grounding
- I moved things around to make it a little easier to debug
- I have made the SMD pads to the teensy longer to make it easier to do hand touch-up soldering.
The main challenge I think is that I am trying to go straight from breadboarding to miniaturization. This makes it a bit harder to debug, not to mention solder. Right now I am not using a stencil which makes the solder paste application very tedious and error prone. Hopefully these improvements will make it a bit easier. You can find the new board on oshpark here:
Custom Teensy Bringup
02/07/2017 at 04:43 • 0 commentsI am having trouble getting my custom Teensy LC to boot up properly. The teensy is getting programmed by the bootloader chip and I see the crystal oscillator start running, but I am not getting any USB comms whatsoever. If anyone has any ideas, you can see more details and post a reply on the prjc forum here: https://forum.pjrc.com/threads/41994-Custom-Teensy-LC-with-MK02-accepts-bootloader-but-no-USB?p=132921
Breadboard Prototype
02/03/2017 at 05:13 • 0 commentsBefore manufacturing a fully miniaturized system it is always wise to prototype at a larger scale first. This will help find bugs that will reduce the likelyhood of having to do a board respin later. In my case, must of the components I wanted to work with could easily be bought on Adafruit of Sparkfun with easily breadboardable headers.
In this breadboard prototype, I connected two Teensy LC micro-controllers to two wireless transceivers, microphones, speakers, etc. I wrote some code to configure one as a transmitter and one as a receiver to test the communications protocol/procedure, bitrates, and the system as a whole. Here are some of the lessons I learned:
- The 3.3V regulator on the teensy is not powerful enough to power the receiver and speaker at the same time. I needed to have an external, higher-power regulator.
- The Arduino library for the RF transceiver doesn't support the high-data-rate mode so it had to be modified for this application.
- Any mic used needs high gain in order to be able to hear a human voice while attached to a lapel. Because a mic amplifier takes up valuable space and power I have found a mic that has an internal low-power amplifier. In addition, the teensy has an internal amplifier than can be used if additional gain is needed.
- I thought the RF module had built features that made it simple to operate ( such as a power-on-reset feature) but it has been proven that it doesn't. Therefore, I have found that additional pins need to be connected to support all the modes I need.
- Some times the Teensy doesn't play well with the RF library, therefore a manual reset button is a must and board space must be used.
- The speaker amplifier consumes considerable power so it is necessary that I choose an amplifier that has a shutdown mode.
