• Restoring lost connections
    3drobert07/28/2024 at 03:19 0 comments
    Now If I am printing from file and I lost connection then I can restore printing from last position and resume fine.
  • more enhancements
    3drobert07/27/2024 at 04:11 0 comments
    - Added LM358 and problem resolved.
    - Ploting XYZ positions.
    - Axis velocity estimations.
    - Allowing to change spark ON time .
    - Start connection to printer through NodeJS serialport and showing printer messages.
    - Changed 100uF capacitor by 660uF.
  • Using Blender .obj file to route EDM job
    3drobert07/26/2024 at 04:08 0 comments
    Now I can import .obj files from Blender besides .ngc files from InkScape.
  • Updated design
    3drobert07/25/2024 at 02:49 0 comments
    Updating design replacing UA741 with LM358 and adding 7805 to relay module.
  • Dual supply OPAMP voltage follower without negative source
    3drobert07/24/2024 at 21:01 0 comments
    I have problems to get real values at lowest voltages on ADC pin because I am using an OPAMP for symetric source (UA741) and I'm using ground for the negative DC PIN.
    I can resolve this by two methods:
    1.- Waiting for LM358 I buy recently which handle single supplies.
    2.- Adding voltage biasing and correct received values though software but I loss usable resolution.
    Falstad simulation
    Geogebra graphic function
  • New EDM features
    3drobert07/23/2024 at 20:45 0 comments
    New features added:
    - Three grid helper added in threeJS view.
    - Changed axis colors in threeJS view to fit according to printer.
    - Show electrode option in threeJS view and change diameter on it.
    - Moving electrode forward based in estimations and do stop and back based in realtime.
    - Allowing Invert print direction (print file mode)
    - Allowing down electrode without change XYZ (to feed worn out electrode in print file mode)
    - Reset XYZ button.
    - Showing voltage values. (Added OPAMP in schematic for ADC pin)
    - Relay to avoid positive electrode has dangerous voltage when IGBT is in off mode.
    - Led connected to relay to dischage capacitor when IGBT is in off mode and to advise the electrode has voltage.
    Next::
    - Allow import file from a Blender scene with a line path.
  • Testing algorithm to execute EDM from GCODE file
    3drobert07/22/2024 at 12:19 0 comments
    Doing EDM machining from a GCODE file. Testing algorithm to execute EDM with XYZ displacement.
  • Voltage multiplier using 555+mosfets for EDM
    3drobert07/20/2024 at 18:56 0 comments
    Now I use 555 with Mosfets to avoid the current 555 limitation.
    Also I printed a support for one ER32 chuck and I have ready implemented an algorithm to move electrode according to .ngc files generated with inkscape GCODE tools and I can see the imported file in a ThreeJS canvas.
    Falstad simulation
