Display & keyboard routines (and hardware fixes)
A project log for TMS70C02 single board computer in two parts
The T.I. TMS7000 line of micro controllers is an interesting architecture. These boards will provide a new platform to explore it.
fjkraanfjkraan 09/18/2024 at 09:160 Comments
The key scan is now working as it should, the key value to display pattern routine too. This startup pattern should scroll to show the remaining 'C02' characters of the message, but that is a ToDo item. Now functions should be assigned to the keys, at least for the values 0-F, memory, up, down, ... Most inspiration will probably come from the MikroKit09 and MPF-I.
