3D Printed planter ready to integrate the Smart Plant powered by integrated solar panels
Base_1.stlBase design number 1. It integrates horizontal holes for the screwed quick 6mm (Outer Diameter) plugs and 3d printed internal guidance for water distribution. It's the red design in the pictures.Standard Tesselated Geometry - 4.14 MB - 07/28/2024 at 15:28 |
Base_2.stlBase design number 2. It integrates vertical holes for the screwed quick 6mm (Outer Diameter) plugs. No integrated water distribution.Standard Tesselated Geometry - 811.18 kB - 07/28/2024 at 15:28 |
Base_3.stlBase design number 3. It integrates vertical holes for the screwed quick 6mm (Outer Diameter) plugs. No integrated water distribution. The flushing system can be added with a 6mm flexible pipe. It's the green design in the pictures.Standard Tesselated Geometry - 924.50 kB - 07/28/2024 at 15:28 |
Hanger.stlHanging part for the rearStandard Tesselated Geometry - 105.87 kB - 07/28/2024 at 15:28 |
Top.stlUpper cover to protect the electronicsStandard Tesselated Geometry - 221.28 kB - 07/28/2024 at 15:28 |
